Question about LG 37LC7D 37 in. LCD HDTV
37 inch LG LCD won't turn on due to power failure
Lg lcd 37 inch tv won't turn on due to power failure
  • Anonymous Mar 13, 2014
    hiker 37 inch LCD TVblue light on but t_v won't come on
  • LG Master
  • 458 Answers
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
  • David Brown
    David Brown Dec 29, 2013
    It still has a Good picture other than the mark
Anonymous
SOURCE:
How to fix a lg tv 47inch with black screen no pictur 47LB5900 model
The red light merely indicates power is getting to your TV. There may be an open internal fuse or power supply failure.
Jul 17, 2016 | LG Televison & Video
Medion lcd hd 31.5 inch tv won't turn on
I bought one also from ALDI for my son's Xbox 360, it is only 3 weeks in use and I have the same problem. The red led is on, indicating that it is in standby mode and recieving power but I can't turn it on either by pressing the power on button on the TV it's self or the on button on the remote. This started happening a few days ago and it's totally random. I found that if you unplug the TV from the power point or alternatively switch off the power point for a minute, than power it on again it will "WORK AGAIN" for a while. Like I said it is random, eventually it will return to the not being able to be switched on state at which time you will have to repeat the process. So thus, this is not really a solution. I am about to return the TV for a refund, and it's a shame because otherwise it's not too bad. and looks OK too.
Jan 21, 2013 | LG 37LC7D 37 in. LCD HDTV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 10, 2010 | LG 37LC7D 37 in. LCD HDTV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
37 inch LG LCD 720p
If everything else on the remote works, most likely the PWR function on the remote is not working.
This may be a problem with the conductive rubber membrane under the button, or the matracy circuit is not reading the function due to any number of problems.
You can call the manufacture parts rep to see if it is possible to have parts for the remote. Most of the time, they are not worth to service, and parts are not sold to support remote control service. You will most likely have to order a new remote from the manufacture rep.
I suggest to NOT buy a universal remote. They rarely can do more than the most basic functions. Many times universal remotes have different issues with different models of sets.
Jerry G.
Jul 11, 2008 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37 in. LCD HDTV Logo
2,002 people viewed this question
Ekse
RONALD CARTER JR
