SOURCE: Bike won't start, won't turn over, lights
Changed the FOB battery in mine andf it was the problem, try it!!!
SOURCE: 05 katana new bat new starter new relay still
check these things: is the engine run/stop switch pressed? is the bike in gear? is your safety switch always depressed?
SOURCE: Electric start not working
The starter relay may have a loose wire or aone of the battery cables is poorly connected. To find the relay, follow the positive battery cable. Ck the negative cable connection on the frame.The small wire on the r4elay is the wire coming from the start button. There must be current there when you press the button. Good Luck, Ned
SOURCE: Bike won't start. Battery is good. Lights
Is your kill switch on it is located on right side of handbar small red off-on switch
SOURCE: the bike won't start.
sounds to me as though your battery is very low on power, either that or your starter motor is stuck and wont turn which will pull loads of amps from battery and possibly dim headlight to nothing.
