Kenmore 24032\24036 Top Load Washer Logo
Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 series washer not spinning/draining
My top load washer stops after the rinse cycle. It does not make any noise, it just does not spin and then it will not drain either. I do hear a "click" when I put the lid down. Model number is 20892990. Please help!
  • sarahrosheim Mar 03, 2009
    The washer is currently full w/ water. Can I fix the lid switch with water still in it? If not, how do I get the water out??
  • CalvinandHob Mar 22, 2009
    Model number is 20892990. It's a top load series 80 Kenmore. It's not spinning anymore. When you push the start button, you can hear what I think is the motor spinning, making a ratcheting sound but nothing else happens. I'm thinking there's something wrong with the transmition. If so how can I fix it? Can I replace a gear inside?
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Mar 03, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316510
Points
2771
BAD LID SWITCH-MIKE
  • 2 more comments
  • Anonymous Mar 03, 2009
    BAD LID SWITCH-MIKE
    unplug washer,remove the console head screws,1 on each side,flip the head up,you will see the lid switch jack,unplug it,cut the 2 outside wires and wires them together,plug the switch back in the jack,screw head back,you have now by passed the switch and all should work,plug in and test-mike
    please change your rating to a fixya as i have emailed the fixya repair to you,thanks-mike
    you give me a thanks for trying then ask me to fix it for you again,what up with that?????????????
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Won't drain or spin
this is the moptor coupler
about 12 dollars and 20 mins f your time
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
2helpful
2answers
Kenmore 70 series Washer will not go to spin cycle
Check the lid switch. That is a VERY common problem on these models.
Alexander
vince
