Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Anonymous Posted on Mar 26, 2013
Bosch 100 series wonn start. lights stay on for wash rinse spin, but door lock doesnt light
prem mathew
Level 3:
  • Bosch Master 662 Answers
  • Posted on Apr 13, 2013
prem mathew
Bosch Master
Level 3:
Answers
662
Questions
Helped
265466
Points
1748
Suggestion plug off the wall for 30 minutes, may re-set.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 25, 2007
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
douglas smith
  • 1462 Answers
  • Posted on Jun 14, 2007
SOURCE: Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 09, 2009
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 11, 2010
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
Anonymous
  • Posted on Mar 21, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
The door is locked and the Finished/Spin and Wash Lights are all flashing alone with a beeping tone. This is in ALL wash modes except off.
my machine did that when stuck on spin cycie all i did was unpluged it for a few seconds and pluged it back in and it let me start all over again and open the door
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
8helpful
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
3helpful
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Bosch logixx 8 front loader won't start - it keeps beeping.
Yes.
Child lock active.
Hold start button 10 seconds.
Then it will deactivate.
If this is not the case, door lock fault or main board fault.
1helpful
3answers
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
