SOURCE: i would like to Reset/Retrieve Password for Copier
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Testimonial: "THANKS A LOT THAT WAS SWEET IT WORK THE MAGIC GOD BLESS"
SOURCE: i want service manualto canon ir-2016 ir-2318
haloo try thy link , i canot upload the manual
http://www.girlshare.ro/490546.1
SOURCE: ir 2318 shows "out of toner,whilst there is new
open the front cover .there u will see a blue handle .turn it clock wise while pressing the handle on it, u remove that by pulling ad replace the same with a new one in the same oppsite manner
SOURCE: when i put my canon
this is error code for main motor failure, you can try to reconnect main motor, look for breakege of gears, reconnect dc controller, or the main motor must be replaced or dc controller, or ...
As you can see that there is a lot of things that can be fault, so call service!!!
