I have a sportsart 3000 series treadmill, with an Error 7 message. The incline had stopped working but I was still able to use it. Now this Error appears and it will not work. Can anyone give advised as to how to fix it please.
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
SOURCE: Hello I own a sportsart 6320 treadmill and I do
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor brushes they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then reassert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then callSports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
SOURCE: E 7 error code is displayed on my SportsArt 1210
i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is [email protected]. not posting my number here.
SOURCE: I have a SportsArt treadmill
www.sportsartamerica.com/.../repair_manuals/6300_6310_ELECT_REPAIR_MANUAL.pdf
www.sportsartamerica.com/SAF/.../T652_ELECT_REPAIR_MANUAL.pdf
Above is the repair manual for your type of unit.
when things like this happen usually it is the Motor controller, drivers, breaking down under load, or the speed controller, or indeed the micro controller, it is difficult to isolate exactly what it maybe without actually examining the unit.
http://www.treadmilldoctor.com/Troubleshooting
Above is a troubleshooting website that may help you.
SOURCE: Hello. My sportsart give's error 7
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
