1999 Pontiac Grand Prix Logo
A
Anonymous Posted on Feb 02, 2018
I have a 1996 pontiac grand prix with a 3.1L that is overheating installed a new thermostat and a new water pump bled air pocket out of system changed radiator cap. car runs at about 210 degrees in driveway all day long take it for a drive and temp fluctuates between 150 and 210 then over heats
Bill Boyd
Level 3:
Top Expert:
  • Pontiac Master 53,816 Answers
  • Posted on Feb 02, 2018
Bill Boyd
Pontiac Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949277
Points
172802
Indicates a head gasket problem
at idle the gasket is sealing but under load is allowing compression into water jacket
do a compression test
check cat converter for failure blocking exhaust
run fault codes to check for mixture control problems
5 Related Answers
salsaurbana
Luis Rondon
  • 56 Answers
  • Posted on Nov 19, 2008
SOURCE: 1999 Pontiac Grand Am Overheating
It is probably the problem. To make shure that need to change the gaskets, one of the symptoms use to be thet the temp rises when you are running at speed 50+ average, where is supposed that the car gets a lot of air due by the speed and nobody thinks that will be overheated.
Anonymous
  • Posted on Dec 26, 2008
SOURCE: 2002 pontiac grand prix over heating
Are your electric fans engaging or turning on?
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Mar 22, 2009
SOURCE: heat fluctuation on temp gauge
change the sending unit to the fan, if that doesnt work check for power too the fan or even a bad fan
Anonymous
  • 73 Answers
  • Posted on Aug 06, 2009
SOURCE: 2004 Pontiac Grand Prix OVERHEATING!!!
Have you shop perform a "leakdown test." You probably have a bad head gasket )or a leak in the gasket).
Anonymous
  • 205 Answers
  • Posted on Jan 06, 2010
SOURCE: 2001 Pontiac Grand Prix...overheating. Changed
Did you bleed the radiator after refilling because it sure sounds like you have an air lock in there.
2004 PONTIAC GRAND PRIX OVERHEATING
Check the operation of the heater control valve. It will be conected to one of the smaller hoses leading to the heater core from the engine.
1helpful
Running entirely too hot....
sound like need bleed air out of the cooling system.most newer vechicles when make repair on coolant system parts cooling system need to be bled.
My grand prix is not circulating coolent would the water pump always leak if it is bad
No, not always. I would check your thermostat first. You possibly could have an air pocket in the system. I would lean towards the t-stat though. Hope this helps, TJ
What is the proper operating temp for a 2000 pont grand prix gt 3.8ltr?
The thermostat opens at 195 F degree, and if the cooling system runs properly, then the temperature will stay the same because the radiator will exchange the heat to air stream. If the radiator is partially obstructed, sometimes only 15%, or there are air pockets in the system, or the water pump is giving up, then the temperature will increase.
3helpful
2006 pontiac grand prix vary little or no heat
Are you sure you got all the air out of the cooling system? Air pockets are very common problem when you do any work to the cooling system. An air pocket will do what you discribe.
1helpful
Changed thermostate still overheating
what about the water pump? is the water circulating
is the electric fan working? check all these things outlook in the radiator see if the water is circulating feel the top hose is it cold or hot when the engine is runing
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
