NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
A
Anonymous Posted on Mar 23, 2013
[email failed] Must issue a STARTTLS command first.
Btinternet rejected my password to obtain my E mails
If you normally use an email program like Outlook or Mac Mail, try logging in to your webmail. If you can see your webmail OK, then it's likely to be a problem with the way your email program is set up.
http://bt.custhelp.com/app/answers/detail/a_id/49512/c/7339/session/L2F2LzEvdGltZS8xNDc4MjExMzgzL3NpZC96SVllVUwybg%3D%3D
may need to reset password if you can't get into web mail
if you can check the authenication method you selected in the email program
from
http://bt.custhelp.com/app/answers/detail/a_id/9962/c/7339
IMAP incoming server option
Incoming Mail Server: mail.btinternet.com
Port: 993 (this should be automatically populated if you tick the SSL Encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet password
Root folder/path:
POP3 incoming server option
Port: 995 (this should be automatically populated when you tick SSL Encryption)
POP from folder: By default, POP will pull emails from your Inbox
SMTP outgoing server
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selection of SSL, so you'll need to check this)
Authentication: PLAIN
I cannot get or send emails. my server is not working
This indicates either an incorrect password or server settings. Make sure your account is setup as follows:
IMAP
Root folder/path:
Folder separator: . (full stop)
Please do NOT enable "secure password authentication" (SPA). It's not needed when you use SSL encryption and won't work.
If your IMAP client supports it, we recommend you also set up the following folders:
Trash
Sent Items
Drafts
POP3
Port: 995 (this should be automatically populated if you tick SSL Encryption)
SMTP
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
I am using GMAIL with Outlook Express but my outgoing mail does not go out as all my parameters is set properly accordingly
Gmail will no longer accept 'pop' remote access to accounts. You have to logon to the account via your browser and read your mail.
Jun 25, 2014 • gmail.com
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was '[email protected]'. Subject 'Forthcoming stay at the Don Jorge Apartments',...
could be an incorrect e-mail address
call the receiver and ask them to send an e-mail to you then reply to that e-mail by clicking on the reply tab
tell them to use subject test one so that you know who it is from
2helpful
I have gmail account and have already forwarding pop3 and smtp but i dont know how can i fill all e-mail settings on my phone samsung-sgh-e-250.my e-mail adress is:[email protected] help me...
    Incoming Mail (POP3) Server - requires SSL:pop.gmail.com
    Use SSL: Yes
    Port: 995Outgoing Mail (SMTP) Server - requires TLS3 or SSL:smtp.gmail.com (use authentication)
    Use Authentication: Yes
    Port for TLS/STARTTLS: 587
    Port for SSL: 465Account Name:your full email address (including @gmail.com or@your_domain.com)Email Address:your email address ([email protected] orusername@your_domain.com)Password:your Gmail password
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
2answers
Sir l want to know GT S3653 Email setting
Enable POP3 in Gmail.
Save Changes when done.
Configure your client to match the settings below:
Incoming Mail (POP3) Server - requires SSL: pop.gmail.com
Use SSL: Yes
Port: 995
Outgoing Mail (SMTP) Server - requires TLS or SSL: smtp.gmail.com (use authentication)
Port for SSL: 465
Account Name: your full email address (including @gmail.com or @your_domain.com)
Email Address: your email address ([email protected] or username@your_domain.com)
Password: your Gmail password
2helpful
L have been looking for the smtp and pop3 server details for my gmail account on my erricson C903 can you help me.
Use SSL: Yes
Port: 995 Outgoing Mail (SMTP) Server - requires TLS or SSL: smtp.gmail.com (use authentication)
Port for SSL: 465 Account Name: your full email address (including @gmail.com or @your_domain.com) Email Address: your email address ([email protected] or username@your_domain.com) Password: your Gmail password
1helpful
L have a gmail email account and l want to receive them on my phone and be able to send them. my email address is eddysthl@gmail. com
You would need to create a new email account on your phone.
The Incoming Mail Settings for gmail is pop.gmail.com Use SSL needs to be selected. The port number to use is 995
The Outgoing Mail settings is smtp.gmail.com. You need to use authentication Port for TLS/STARTTLS: 587
Port for SSL: 465
The username needs to be your full email address.
I hope this helps
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
