Washing machine won't spin out the water, agitate or spin
SOURCE: Washing machine won't spin or agitate
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
