The lights for the clock/timer are all still on at the left hand side of the oven, just the oven/grill function symbols on the right are not lit and won't operate.
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
SOURCE: Neff oven B1641 child lock
I actually had the same problem and got the solution. Maybe its a bit late, but hopefully there will be somebody who find this useful as well.
Its not an error. The -5- indicates that the oven is "children protected".
- Put the left ON/OFF switch into its OFF position (the left switch)
- Turn it quickly 3 times: one click to the left and then one click back to right again [light position, Off position]
=> The message disappers.
If you do this again, the protection is switched on again.
Greetings from Germany
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
