Question about Viking 27" Professional Select Built-in Electric Single Wall Oven
Viking oven - very loud vent fan noise, run 30 min. after 'off'
The problem is with a Viking 30" single electric oven (VESO 105) purchased around 2003. It has dual cooling fans for the electronics. They come on at low speed for around 15 minutes during preheat. Then, a relay clicks and they change to a very high speed, making them very loud - too loud for comfort.
On turning off the oven and opening the door to speed cooling, they still run loudly at high speed for 30 minutes.
The fans have been inspected; the noise is not from bearings or a blade hitting an obstruction.
The fan tstat switches have been replaced and lifted slightly off the metal surface (to reduce contact). This did not solve the noise problem, and actually caused the fans to run longer (45 minutes) after oven shutoff.
Three different Viking tech support reps have given 3 different suggestions (replace the stats/fans; replace the wiring harness and control board; live with the problem, it is a design flaw in the model) but seem to just be guessing.
Has anyone else experienced this problem and actually found a fix? Many thanks in advance for any reply.
  • 2 more comments
  • Stuart Smolkin Mar 01, 2009
    There is nothing stuck in the fan. The tech has opened up the casing and inspected both fans twice.
    There is nothing stuck in the fans. The local Viking service manager has inspected each fan twice.
    Something in the oven (control logic? defect?) makes the fans operate at very high speed, and that is what makes the loud noise. Something also makes then run at this high speed for 30-45 minutes after the oven is turned off, even though the inside of the oven is cool to the point where you don't burn yourself by touching it lightly. Replacing the fan t-stat switches did not solve this problem.
    I appreciate the suggestion to replace the control board. Would you kindly reply again with a little more detail?... Have you seen this specific problem on a Viking range and solved it by replacing the control board? Viking also recommended replacing the wiring harness - have you ever seen this contribute to the problem? Lastly - do you have a rough idea of the cost of the control board (and wiring harness)? Thanks in advance for your first post and for any additional detail you can add.
    Thank you for suggesting that the problem is a faulty component on the control board. Will Viking do a board level repair of a component? Or, if Viking will want to replace the entire board, can you recommend a company to repair the board? Thanks in advance for any additional information.
    New Friend:
I have this problem. If I push the burner grates backward gently against the fan exit housing, the noise goes away. Completely. I don't know how that fits into the cause of it, it seems to me to be a loose piece of sheet metal.
It's frustrating
Posted on Apr 14, 2018
    Scholar:
  • 165 Answers
U can get the required parts from here: http://www.partselect.com/
also any good local reparing technician will do the job once u get the parts.
Posted on Mar 01, 2009
    Sergeant:
  • 250 Answers
Its the control board fault as the components in the board are getting loose somewhere internally or not giving proper voltage required to the fan to make it run and due to that the fan is running in different speed as normal and turning off so the board needs to be checked and that faulty part should be located and replaced.as replacing whole control board is not much advisable as its just a fan problem so it will be a minute component replacement to make the unit proper.
    Genius:
  • 1,550 Answers
Your facing this problem due to defective control board .
You need to replace it .
  • Anonymous Mar 01, 2009
    This is due to defective control board you are facing this problem . By replacing the control board your problem will be solved . Since you have mentioned fan runs at high speed for about 30 minutes it is definitely due to bad control logic .
    The control board will cause you around $150 -200 .
    You can get one from the link below
    Viking parts
    Hope this helps .
    Sniper:
  • 113 Answers
Check if something is Stuck in the fan, and let us know.
Good Luck!!!
neo
    I thinks there is a problem of overheating, so that the fan runs fast to cool down the temperature.
  • Viking Master
  • 19,396 Answers
That is probably a defective control board, give me the model number.
  • Ginko
    Ginko Mar 01, 2009
    If the problem is only the noise, then you replace the fan motors.
    If instead, as I suspect the problem is that the fans stay at top speed for too long, then the problem is either the temperature probe, or more likely a defective control board.
    You need to understand if the fans are operating on their usual speed, if they are , replace the fan, if they are not , test thermostat and control board.
    You can find parts and schematics by entering the model number here.
Anonymous
SOURCE:
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Hello, I am having trouble with my built in Zanussi ZBF 360. When I turn the oven on to the fan symbol the 'on' light comes on and when I turn to the required temperature the heating light also appears. ...
If you cannot hear the fan going, then it is possible the fan is faulty, and the element has probably failed as well.
Both these components can be accessed by removing the panel at the rear of the oven compartment
Feb 02, 2011 | Zanussi ZBF360 Electric Single Oven
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
Jul 01, 2010 | Viking 27" Professional Select Built-in...
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
The fan in the oven is really loud and making weird nosies
It could be worn motor bearings, a loose fan, or the fan blades catching the cover.
You are going to have to remove the cover over the fan to determine exactly what the noise is.
If it is worn bearings, then only solution is to replace the fan motor.
Dec 16, 2009 | Viking DEDO205 Stainless Steel Electric...
Lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Jan 28, 2009 | Viking VESO105 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Viking 27" Professional Select Built-in Electric Single Wall Oven Logo
2,747 people viewed this question
Top Viking Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Viking Oven Expert? Answer questions, earn points and help others
