Question about Black & Decker FP1445 Food Processor
Need FP2500IKT processir part #77790.
Need center post bowl coupler. mine came apart. and without this part the whole process is useless. don't want to buy another one.can you help?
    New Friend:
Do NOT try " ABTECPARTS US ". They use Canadian based processers for orders placed in the USA. If your credit card is declined, the mickey mouse you have to go through isn\'t worth it.
Posted on May 13, 2014
6ya staff
SOURCE:
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
Need to clean inside the handle of the KFP600WH
SORRY but fixya has no idea what you can do about cleaning .
Oct 22, 2017 | KitchenAid KFP600 Ultra Power 11 Cups Food...
GE 14-cup digital food processor; bowl cracked, either by lid fastening or ice cubes in the bowl while chopping mode; don't know exactly. Is this covered by warranty ? Or are separate bowls available...
how old is your processor? did you buy an additional warranty when you purchased it? If so you should read the paperwork. Whats covered,and not, should be listed. you can probably buy a replacement bowl for it on the website.
May 11, 2011 | GE Food Processors
The motor runs but the shaft that turns the blade does not turn.
Depending on the processor there are a few things that would cause this. If it isone piece then there may be a little gear box or there can be a direct connect from the motor to a coupler of some sort. On the 'bowl' end where the blades are they will be attached to a shaft. So the gear box could be stripped or worn out, the coupler could be loose on the shaft, or the blades are loose. The last two are the most likely. Usually if it has a gearbox it will juice bricks.
You need to see if you just need a replacement bowl or if it is the drive end. This is a bit tricky but you need to remove the bowl (or blender or?) stop the blades with something other than a finger ie a chopstick or knife. Then try to turn the shaft or coupler. If it turns then something is loose on that end. If it won't that means the coupler and blades are still on. There may be a safety on the power/base that will stop it form working without a container so its a bit harder to check. Usually it is just a rod that is pressed down.
It's worth a try but if you just check the container end carefully it will tell you just as well.
Once you know which end is the problem you can figure out what to do with it. If it is the blade and container end. That can be replaced fairly inexpensively. If it is the power end that can be as much or more than a entire new blender. You can get repair parts from the manufacturers repair depots or a repair parts place. A quick search with the make and model and repairs parts should find you several sources. As well you can go to the company website and look for repair under support.
Jul 07, 2010 | Food Processors
It won't turn on
It may simply be that the bowl and cover are not completely in position. The bowl must be locked in place with the handle straight to the front, only then can the lid be locked into place. Then the pusher must be be in--it has a part that interlocks with the lid and prevent the motor from starting until it is in position. Hope this helps!
May 30, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I need a new lid for Braun multipractic 4259. Who stocks one?
Did you find a lid? I have a used one and would gladly send it to you for the cost of shipping from NH.
I warped the bowl for mine in the dishwasher and have since replaced it with a new food processor so would be happy to give away the useful parts (lid, pusher, blade, discs & carrier).
Sep 06, 2009 | Braun Food Processors
I need a replacement bowl for the Oster 3212 Food Processor
I contacted the manufacturer and bought the bowl. This is frustrating as I had contacted their authorized service center and was told the bowl was unavailable.
Jun 24, 2009 | Oster 3212SNB Food Processor
CFP10 Food Processer
I probably have the part you need. It is the gray post for the shredder/slicer attachment. My CFP 10 died today, and I will send you the post if you give me an address to send it to. Barbara Palser
Nov 17, 2008 | Black & Decker FP1445 Food Processor
Black & Decker FP1445 Food Processor Logo
143 people viewed this question
Top Black & Decker Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
