Washer starts cycle then after a couple of minutes stops with a E10 error does anyone know what e10 means. thanks
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
E10 on Zanussi W/D
I had E10 on Zanussi W/D.
The machine would wash but not dry.
Changed the water inlet valve assembly.
All working again.
All credit to wildwest1959, thanks.
Check to see if the water inlet is blocked.
the link below takes you to the manual, go to page 22
http://www.serviceforce.co.uk/pdfs/U21039.pdf
hope this helps
It is simply that water is not getting into the machine at a "reasonable" speed. Or NO water is getting in. It can be as simple as the water turned off at the place you connect your washing machine.
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
