Troy-Bilt Tuffy Tiller Parts Catalog - Breakdown Manual Logo
A
Anonymous Posted on Mar 16, 2013
Huffy tiller has stopped running - Troy-Bilt Tuffy Tiller Parts Catalog - Breakdown Manual
Derrick Schultz
Level 3:
Top Expert:
  • Troy-Bilt Master 11,405 Answers
  • Posted on Jan 23, 2019
Derrick Schultz
Troy-Bilt Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2330508
Points
23972
Some fixya user told me a website reliable-store it is very good..
I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try free
2helpful
Electric mantis keeps stopping
could be the battery has developed a memory from only partially charging it causing these symptoms .try checking the voltage in battery before and then immediately after it quites to confirm.if no issue found run it untill it stops and check electrical for over heating parts.
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this,...
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
Craftsman model 917.299011 carburator problems
you might want to check for spark when it stops running
While operating the Honda FG-100 mini tiller, the tiller suddenly stopped turning. The engine runs fine. I couldn't find any advice in the manual. Any help would be greatly appreciated.
If the tines become jamed, the tiller will stop. This is especially true if you are preparing your lawn for seedng without doing an preparation of the ground. Also, check you accerleration line, there may be a loose connecton.. Otherwise, sounds like a service issue.
6helpful
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
My tiller starts and runs it also turns the tillers but when I try to till the tillers stop. It is a MTD
sounds like a belt or clutch problem. you didnt give enough info to look up the tiller.
Jul 06, 2009 • Mtd Garden
Top Troy-Bilt Heavy Machinery Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
