My iphone 3g has been jailbroken with sn0wbreeze and i reset factory and won't to enter recovery mode
IH8Sn0w, the developer of Sn0wBreeze recently announced on Twitter that he had released an updated version to his infamous jailbreak tool. This new version of Sn0wBreeze supposedly works with every device on iOS 4.1, including the iPad iOS 3.2.2.
Sn0wBreeze is like PwnageTool for Windows. It allows you to create a custom firmware while preserving the baseband and hacktivating the phone, thus making it possible for you to unlock using UltraSn0w.
Historically, most people have had problems at some point using Sn0wBreeze. While I have a huge respect for iH8Sn0w, I still wouldn't recommend the use of his tool. If you don't have a Mac and can't use PwnageTool, I'm sure you can always find a friend or family member who can create a custom firmware for you.
At the end of the day, do what you think is best for you. If you do decide to jailbreak using Sn0wBreeze, I'd like to hear about your experience. I hope you can prove me wrong and show me that SnowBreeze is indeed a great jailbreak. You can download SnowBreeze and also this Whatsapp Recovery for more details for the recovery methods.
Try this first:
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup with the help of iPhone Data Recovery. To do that, follow these instructions:
1. Connect the iPhone's USB cable to your computer, but not your iPhone.
2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Definitely go to fix iPhone stuck at Apple logo.
Try t o see if you are using the latest snowbreeze version which is compatible with iphone 3G.I will recommend you ti use WhitedOOr firmware for iphone 3G,as it is much faster to use.
Try to put the phone in DFU mode.Click Power button+Home Button for 7 secs;screen should be black,then release power button but continue pressing the home button for 5 secs.Then connect your iphone to itunes through USB cable.It should get detected by then.You can restore then.
my phone not work
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "the last option helped alot thanks x"
SOURCE: How to recover Restriction Passcode - iPhone 3g 2.2.1 jailbroken
ok! I figured it out... What I did was, I simply restored the phone with the backup taken from another phone with the same name and now my Restriction Code is blank (as it was blank in the other phone)
SOURCE: jailbroken iphone 3g frozen screen
samevthing happened to me your gonna have to plugg your iphone into the comupter and hold the power and home button down at the same time until it shuts off. Keep holding the buttons down until it powers back on. there should be a picture of a guy wearing holding his hands up in the air on your iphone and itunes should open up on your computer. Now you will have to restore your phone.
SOURCE: my iphone wont load up i did a reset on the phone
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
SOURCE: iphone 3GS jailbroken and unlocked 3.0.1 - emergency call mode
u need to unlock the iphone again then only it work, go to unlock store or buy the software from online
To reset your iPhone settings,
From the home screen, Tap Settings > General > Reset > Reset All Settings.
If iPhone won't turn on, or the display freezes or doesn't respond Let me know if this helps or not, there are other resets available : If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
Still having problems? Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
