None of my apps are working including the online store, when I click it just doesn't open. My internet is working and also the names of all the apps are weird. The maps app is called Appexmaps, the photos app is called Microsoft.WindowsLive.ModernPhotos and the weather app is just "app".
Try creating another admin account
This person had similar problem and that worked
Solved Windows 8 apps wont load
SOURCE: I keep getting error notices when I try to open various apps
Hi Julie,
The problem encountered is a launchd problem (that's it's technical term!) and generally is due to too many apps or processes running for your mac to cope with. I would suggest getting more memory. In the meantime here are a few things to check on.
The last of those (the one for Windows Sharing) is the one that will probably have the most effect on your system but do them all anyway. You can also use Cmd-Alt-ESC which brings up a list of running apps that you can force quit from if they don't shut down normally or hang (Not Responding) although this is often a last resort.
But more memory is what you really need.
All the best
Sean
PiDigital
SOURCE: Integrated Webcam doesn't work (E620)
dear you tried everything thats good, now restart the laptop and go to bios and enable the camera from bios.
it worked for me hope it will help you
SOURCE: ASUS Eee 2G surf. changing to google Crome and deleting unwanted
Go into add/remove programs in the control panel or if your running windows 7, go into programs and features and from there you can remove all the programs you don't want on the hard drive.
Then go ahead and download google chrome. You'll have all enough hard drive space left to do things. You won't be able to remove Internet Explorer because thats part of the operating system.
SOURCE: apps lib was not working
Same here, come on archos at least post an aknowledgement on appslib! Day 4 of owning the device, don't let me down after choosing *you*.
Archos 101 user
Fast & Easy Windows Update Fix. Takes Just 2 Minutes (Recommended)
PCHealthBoost.com/FreeDownload
Be sure to disable your anti-virus protection before checking for updates. This very well may be your problem.
or
I suggest changing the settings of your automatic updates as that may trigger it to do this for you.
Then disable any other programs that you can by right-clicking the icon in the system tray (next to the time, bottom-right corner of monitor) and selecting 'exit' or 'quit' or something like that.
If you are having a lot of trouble, you can get ahold of Microsoft at http://www.microsoft.com/protect/compute... too.
To change any settings related to Microsoft Update, go to http://www.microsoft.com/athome/security... .
Besides that, I recommend erasing the cookies and internet data. Click START > CONTROL PANEL > INTERNET OPTIONS. Then in the 'general' tab, click DELETE and erase all of the cookies and temporary internet files and such.
If that doesn't work, try rebooting your machine and tap F8 until you get the boot selection menu. Select "Windows Safe Mode with Networking". Try to go online again and see if you can download updates with that configuration.
If it still doesn't work, you can try disabling your browser add-ons that are installed in Internet Explorer. To do this, click START > ALL PROGRAMS > CONTROL PANEL. Open up INTERNET OPTIONS.
Click the GENERAL tab (if not open). Under "Browsing history", click DELETE... and then DELETE ALL. Put a check next to "Also delete files and settings stored by add-ons.". Click YES.
While still in the Internet Properties dialog box, click the SECURITY tab. At the bottom of the window, click RESET ALL ZONES TO DEFAULT LEVEL.
Now click the PRIVACY tab. Click the DEFAULT button (unless you are unable to). There is a good chance that it may be unavailable, meaning that you are currently at the recommended privacy settings already.
you might have to many programs trying to or accessing your computer or the internet at the same time or a virus
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now
download and install at least one of these all free depending on your operating system
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope this helps
