Initially noticed a problem when clothing was removed and it was completely wet. Tested the spin cycle and the drum does not move. Attempted to begin load from start. Water appears to dispense but drum does not move. We needed to manually move the switch to drain. Water drained then cycle ended a couple minutes later.
Thanks for any help you can provide.
SOURCE: My Axxis wfr 2460 is not releasing the fabric softner from the drawer
You could try a tooth-brush. And after you fill your quantity of softener, top it with water till the exit level of the compartment. You could also check whether water actually pours into the compartment during the final rinsing of the clothes; in this case you should check the inlet pipe screens of your inlet pipe into the machine; which can be done without opening up the machine.
SOURCE: bosch wfr 2460 gb
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
SOURCE: WFR 2460 Front loader
take the soap dispenser drawer out and clean the inside where the drawer fits into. Then give the drawer a good clean including underneath it, it could be caused by soap build up.
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
