I have a Zanussi WDA1055W washer/dryer. I never use the dryer programmes. On a wash programme It seems to be spinning only when it feels like it! Sometimes it will drain and spin fine on one programme, then decide not to bother the next time! So i have to wait for the wash cycle to finish then set it to the drain cycle then set it onto a spin. It does not seem to be able to just follow a whole programme through! Any ideas?
The water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
