My joy stick won't make the chair move.
SOURCE: How do I lock up my Hoveround MPV5?
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
SOURCE: Chair will power up, however
The number of bars that are blinking will also help to indicate what the problem is. Fault codes are located in the back of the owner's manual.Try doing the brake reset as previously suggested or the lock out sequence noted in the manual; call it in if neither of those steps help.
SOURCE: Does my Hoveround need to
Either way will work when charging the batteries and it wion't hurt the chair either way. If you can stand to have the lights scrolling all night when you charge the chair then leave it on If not turn the power off Your charger will tell you when its finished by turning the yellow light green. Hope this helps
