No. You are on two different networks. Regardless of the hardware. Treat the home server just like any other PC or tablet. Make sure it has a dynamic IP via DHCP from your home router or ISP modem. Then connect via VPN.
You will not be able to network the two servers unless you have right equipment and network configuration. You would have to work with your service provider to obtain static IP's.
Internal IPs are irrelevant, because you can assign them your self internally. That means no one else sees them.
SOURCE: cannot access admin functions toshiba magnia sg20
If it was unplugged for any period of time, it is probably reset to default settings. Password is default, etc and you are trying to access with the wrong credentials.
Try resetting it manually and starting as if you just purchased it, if you continue to have problems. There should be a reset button or procedures on how to reset in the documentation.
