Refrigerators Logo
A
Anonymous Posted on Mar 06, 2013
Uline refridgerator not working - U-Line Uline Origins Series Refrigerator/Ice Maker Manual Defrost-COMBO29A
Uline 1175rb under counter fridge. Light says 'OFF' but the on off switch won't power it on.
Sounds like the switch is faulty, but the indicator light circuit works. Get behind it and test it with a multimeter.
https://www.google.com/search?q=Uline+1175rb+under+counter+fridge+not+working
Not cooling
You can ohm the compressor to see if it is shorted but if the compressor is running it cannot be the overload or relay , if not running sometimes you can pull the relay and shake it if you hear any rattling in it it is bad
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
3helpful
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
1helpful
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
2helpful
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
