Waring MX1500 Work Top Blender Logo
Posted on Feb 20, 2009
Turns on but doesn't spin!
The blender unit turns on but the gear doesn't spin!
  • Anonymous Mar 10, 2009
    The blending assembly is fine. It's the actual motor that isn't spinning. Thanks.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
4212
Points
11
It sounds like your blending assembly is shot, you'll have to order a new jar since the blade is not replaceable in this model.
5helpful
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
4helpful
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Where do you get a new gear wheel that is in unit base to make blades spin?
LOOK ON LINE UNDER THE MAKE OF THE BLENDER AND YOU WILL FIND PARTS DEALERS OF ALL KINDS BUT SHOP AROUND AND GET THE GEAR CHEAPER
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
1helpful
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 • Blenders
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
2answers
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Top Waring Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
vince
Are you a Waring Blender Expert? Answer questions, earn points and help others
