The color wheel is your suspect.......usually whines a bit
when bad. In a quiet room, you can hear it when the TV is powered on or off. It spins at 9,000 rpm ( wears out the bearing).
The lamp will not exhibit those symptoms....
Hi, do you hear clicking or like a start up sound? if you do it could be an issue with the ballast,that's the board that powers the lamp.Here's how to replace it: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Does your TV make a "whining, whirling, clicking, or humming noise?" If
the TV have the infamous blinking lights problem and you're replaced
your lamp without success, it's most likely a problem with your color
wheel. The Samsung BP96-00674A color wheels spin anywhere from 6,000 to
15,000 revolutions per minute (RPM’s)--It is one of the few consumable
parts in your Samsung TV. The average life expectancy from our data
logging shows the Samsung color wheels are fairly reliable with a MEAN
average of 5-8 years. Here's how to replace it:http://guides.fixyourdlp.com/samsung/bp96-01579a.php Also make sure door cover is properly shut and also reset lamp timer by unplugging tv wait 5 min and plug it back again.God bless you!
Chances are is the Lamp is bad. Call 1800-222-SONY and they can get you one ordered.
It is a very common thing to happen particularly if you have not replaced the lamp before. Average hour life of the lamp is 3000 hrs.
Hope this helps,
Skyassoc
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
• Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link. http://servicemanuals.vstore.ca/
2 years and three months but, what counts are the hours that it was on. Your software only really effects the way the TV interacts with HDMI inputs and really won't effect much else. The manufactures only expect 4-5000 hours on the lamp. Some go less some go more. You need to replace that lamp most likely.
