A few important bits of information about using faults and fixes on usb drives
w7
First, please disconnect all USB devices and then perform the following steps:
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
Right click the icon of your Flash Drive (It should be F: / E: or something)
And finally, click Allow next to Full Control.
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then return and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
also you might need to do this
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
you might have restore it to its defaults
If you need more help with this post a reply.
