Https://www.repairclinic.com/Video/Video-Landing/476-/Cabrio-Oasis-Washer-Basket-Drive-Hub-Replacement-280145
go here watch video,easy fix
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
SOURCE: Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
SOURCE: Kenmore Elite 110 does not spin/agitate/drain
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
