2002 Ford Explorer Logo
obielu Posted on Nov 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
INJECTORS WONT OPEN FOR MY FORD EXPLORER 2002
HELLO PEOPLE, MY FORD EXPLORER, GOT FLOODED, THE ENGINE GOT STIFF AS WELL AS THE IGNITION. AFTER FIXING THE ENGINE AND LOOSENED THE IGNATION, THE VEHICLE"S INJECTORS AINT WORKING, BUT THE SPARK PLUGS FUNCTIONS FINE, THE ENGINE ONLY STARTS MANUALLY, 'BY PUTING FUEL DIRECT TO THE INJECTORS. PLEASE ONE WITH SUCH EXPERIENCE?
Kiarash Ertebati
Level 2:
Sergeant:
  • Expert 170 Answers
  • Posted on Nov 07, 2017
Kiarash Ertebati
Expert
Level 2:
Sergeant:
Answers
170
Questions
Helped
38252
Points
519
Need to service the injectores or better replace them
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Sep 26, 2008
SOURCE: 1992 ford ranger 3.0
i was once pulling a trailer with a ranger when it suddenly lost power and the engine died. turns out the problem was with the fuel shut off inertia switch. the switch is supposed to activate in case of accident. on my model the inertia switch is located in the passenger side under the glove box. dont know where yours is located. once you find it, just push the button and see if it resets. good luck.
six-of-ten
  • 208 Answers
  • Posted on Oct 28, 2008
SOURCE: 2000 ford explorer 4.0 x-engine is stalling, missing and lose power while driving
I personally would check the fuel pressure. Then I would go back to the coil. I have seen brand new bad coils out of the box. The symptoms of a loss of power point to this component, especially if the car idles well, but loses power when accelerating. Please do not rate this reply - we all are left to grasp at straws since you have changed pretty much everything. Good Luck. Please post the final fix of the problem.
Anonymous
  • 24 Answers
  • Posted on Jan 11, 2009
SOURCE: 2002 E-250 5.4l hesitation during accelleration
Sounds like you could have a bad coil or boots. When I do tuneups on fords I always use motorcraft plugs, and replace the boots that hook to the coils, also buy some dielectric grease to put small dab inside the boot where it slides on the plug. You will probably also need 8mm socket, 7mm socket, and a wobble spark plug socket, or swivel to reach some of them. I usually try to blow air around the intake to clean any dirt off. Then I do 1 plug at a time, and while the plug is out i crank it over or start it a second to blow anymore debris out. Fords are bad about getting misfires on back cylinders. If you take it to a shop beware book time is about 3.5 hours. Could be worse I just got through last week tearing apart a 6.0 powerstroke in 2006 E350 (No access there)
daveleeyates
  • 65 Answers
  • Posted on Mar 24, 2009
SOURCE: Ford Escort 1998 fuel pump not working.
good old ford lol, try looking at the crank sensor its located at the front of the engine tucked in right hand side of exhaust manifold and gearbox, two pin plug, i have also known these to have no end of faults with the fusebox.
easy to remove, and solder the connections inside they all suffer eventually, if your not to handy with cars i recommend taking to a auto electrician, easy if you know how. Good luck Davelee
Anonymous
  • 202 Answers
  • Posted on Apr 17, 2009
SOURCE: 96 ford explorer code p0301 mis fire 1
Sounds like either a bad plug wire, or coil pack. This is about all that would cause the misfire.
Door handles wont open doors
Fixed 1997 Ford Explorer Door wont open - YouTube
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
98 Ford Explorer Door Won't Open Part 1 - YouTube
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
98 Ford Explorer Door Problems- how to open without panel ...
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
Rear doors can't open from inside - Ford Explorer and R
Why does my 2002 Ford explorer crank over but wont start?
check for fuel at injectors could be fuel pump or shut off switch
Car floods and starts hard when first started
ENGINE FLOODING COULD BE CAUSED BY FAULTY FUEL PRESSURE REGULATOR.FAULTY MAP SENSOR, WEAK IGNITION SPARK.DIRTY FUEL INJECTORS LEAKINGSTICKING OPEN. FLOODING OUT ENGINE.CLEAN THE FUEL INJECTORS AND CHANGE AIR FILTER.
I have a 2002 explorer. It runs fine sometimes then sometimes when i shut it off it will not start. It has fire to the plugs. They two times it's happened I checked the shutoff switch it seemed like it...
CHECK SPARK PLUGS SEE IF THEY HAVE BLACK SOOT OR CARBON ON ELECTRODE IF SO.YOUR FUEL INJECTORS LEAKING WHEN YOU TURN OFF ENGINE.FLOODING OUT THE SPARK PLUGS.CLEAN FUEL INJECTORS WITH A BOTTLE SEAFOAM POUR IT IN A FULL TANK OF GAS.AND CHANGE AIR FILTER.
2003 explorer will not start. wait about 1 hour and it fires up but idles rough.
FUEL INJECTORS NEED CLEANING THEY FLOODING OUT ENGINE AND FOULING OUT SPARK PLUGS.THAT WILL CAUSE ENGINE HARD TO START WHEN ENGINE IS HOT.IF IT BEEN A WHILE CHANGE AIR FILTER IT WILL HELP SOME.
2helpful
While starting my 2002 Ford Explorer sometimes it acts as it is flooded and will not start unless I put my foot all on the way down on the accelerator. I believe that this started when I came out of store...
well theres two things that could be happening. first would be the most obvious and to say the fuel pressure regulator is bad. simple test for that would be to pull the vacuum line off of the fuel pressure regulator, and check for fuel in the vacuum line, if so it needs to be replaced. if not the next answer would be if you take lots of short trips without getting the engine warm, the engine will actually flood. its because the EFI tells the injectors to stay open longer and to dump more fuel in the cylinder just as a choke on a carb would do, and if you shut it off during this time it can actually flood the cylinders with fuel.
My 2002 ford explorer wont start. lights come on
first thing to check is the battery and the connections at the battery. if all this checks ok then you should try and look at the fuses for the ignition system. this should get you going in the right direction.
My 1987 wont start a second time after warming up.
FLOODING IS WHAT HAPPENING.CLOGGED OR DIRTY FUEL INJECTORS. IS LEAKING WITH ENGINE OFF.FILL FUEL TANK.PUT A BOTTLE OF FUEL INJECTOR CLEANER IN FUEL TANK.DRIVE AROUND SO THE FUEL INJECTOR CLEANER CAN CLEAN FUEL INJECTORS.
Ford explorer no fuel coming through
disconnect fuel filter on flow side turn key on if it spits fuel you should check the sparkplugs and injectors for propper spray pattern
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
