SOURCE: windows has been shutdown to prevent damage to computer
try restore ur system to factory default state when u purchased it as new u can do that as follows
from ur backup OS cd
or try this
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
if the problem persists after this then i am 100% sure about hardware malfunction that is RAM problem kindly replace and check if it works or if u have two RAM chips installed try each one at a time to find the faulty one
SOURCE: Brand new hard drive was installed a month ago by
Not a good sign, electronics are most prone to failure within the first 30 days of use, I'd take it back to them and see if they will warranty the drive.
SOURCE: hard disk error message.
Sounds like you have an bad sector in with the windows system files. Yes backup now! I would buy another hard drive, you can try to re format and put you stuff back on, but for the price of hard drive buy an new one.
