A humming sound and no movement of tub
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
