Sewing Machines Logo
Holly Williams Posted on Feb 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a replacement foot control for bernina 900
Help I need a replacement foot control and control lead for a Bernina nova 900 generic is fine.
Anonymous
Level 3:
President:
  • Master 643 Answers
  • Posted on Feb 27, 2013
Anonymous
Master
Level 3:
President:
Answers
643
Questions
Helped
272017
Points
1873
Check out the following link he should be able to help
http://www.whitesewingcenter.com/berninaparts.php
3 Related Answers
BJ sewing
  • 300 Answers
  • Posted on Jan 15, 2011
SOURCE: mi need 1 foot pedal
The cord and the control are sold separately.
If it is not working > bring the machine and the control to a Bernina shop for them to check, maybe it is the cord, maybe the control.
If you lost it you need to go to a Bernina shop and buy a new control and a new cord.
Anonymous
  • Posted on Apr 14, 2011
SOURCE: Are Bernina Nova 900 foot pedals still available?
My "new" Bernina 900 (I just bought it) has another foot pedal than Bernina that is perfect : a YDK !
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Jan 07, 2013
SOURCE: I need a Bernina Nova 900 foot control pedal. Where can I find one?
try these sites
ebay
sewvacdoctor.com
a1sewingmachines.com
sewingpartsonline.com
thesewingoutlet.com
2answers
Is bernina 930 a low shank or high shank machine
Bernina has feet that are specific to their machines only. They have old and new style feet depending when the machine was made. You cannot put generic low, high, slant or snap on feet on a Bernina sewing machine.
The foot pedal on my 1530 Bernina is not working. It was woking fine. Then it seemed to slow down and now it does not work at all. Seems be electrical.
Foot control units do go bad. Difficult to say what it could be. Some older Berninas have a capacitor in the foot control which fail. Also, some Berninas have carbon brushes that wear out. It's like a pencil lead, after use, it gets worn down so that it no longer makes contact. If you are mechanical, you may be able to find instructions and replacement parts online. Otherwise, talk to your Bernina technician.
FWIW, there are some Bernina user groups on Yahoo. One is called BerninaThirtySomethings (older Bernina "30 models) that has a lot of knowledgeable and active members who may be able to provide assistance, You will need to have a Yahoo email account and then request admission to the group before posting any questions or viewing the conversations.
Bernina nova foot pressure
The presser foot pressure is not adjustable on the 900 Nova and is not necessary with any Bernina models from the 117L through the 1630 series. If the presser foot bar is sticking so that it is sluggish to respond to the needle plate, the presser bar and bushings will need to be cleaned of oil varnishes in order to function properly. (99.9% of the problem)
The other potential problem although unusual, is that the machine frame has been damaged from a drop or impact, causing the presser bar frame bearings to be out of alignment, hence a sticking shaft condition. You do not want to attempt to correct this as you will likely ruin the machine. Suggest contacting a specialist
Bernina nova
Usually the Niva is a model 900 or a Model 1008 is not a nova?
If a model 900 there is a small hole in the bottom of machine that a small screwdriver can be inserted to rotate the speed regulator
I have often had to remove entire electronic board and send it in to BERNINA to have the electronics rebuilt. With
The Bernina 1008 the least expensive way to cure the problem is to purchase a newer style foot control and cord. In Canada about $99
try these sites
ebay
sewvacdoctor.com
thesewingoutlet.com
1helpful
Mi need 1 foot pedal for Bernina Nova 900
2helpful
Bernina 900 ''Electronic Power'' foot control needs repair
You will need to go a bernina dealer to by those pins the part number is 325 355 031 and each pin cost around $4.00 each
2helpful
2answers
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
