Lexmark X5470 All-In-One InkJet Printer Logo
Posted on Jul 26, 2017
Lexmark 5495 Paper Jam
My friend has a Lexmark 5495. It kept showing a ''Carrier Jam'' message which got automatically resolved after I opened the front cover and re-inserted the cartridges. However, now that I need to align the heads, we have a new problem. The paper does not feed through, it tries to roll through, then starts to wrinkle on the left and does nothing more. I cannot get a paper to feed through at all. Please help!!!
  • ppremock1 Mar 07, 2009
    I have the same problem. I have a piece of paper stuck in the rollers. I can see a very small piece of the paper but can't remove it. I took the three screws out of the back cover but can't remove the cover. I was looking for some one or a manual for instructions on how to get at the feed rollers so I can remove the jamed paper.
    Pete
5 Related Answers
Anonymous
  • 114 Answers
  • Posted on Sep 27, 2006
SOURCE: Carrier Jam
This article gives a few suggestions on how to resolve the issue: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1
Anonymous
  • 2985 Answers
  • Posted on Jan 01, 2008
SOURCE: Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
A
Anonymous
  • Posted on Jan 22, 2008
SOURCE: Lexmark X2350 paperjam/top cover sensor problems
I thought I got all FOD out of my printer, till I turned it up side down.
Pencils apparently find the x2350 very comfortable.
Anonymous
  • 6 Answers
  • Posted on Mar 12, 2008
SOURCE: carrier jam
Try feeding a sheet thru the top mutisheed scanner feed, or look for some paper stuck in the rollers, I have had mine jam up on multisheet copies several times and I get a clear document type error.
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Oct 25, 2008
SOURCE: how do I clear carrier jam on lexmark p6250
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Carrier Jam message in window
http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Lexmark 5495. No paper jam. Gears just spin. Won't grab paper. Paper properly in loading position.
Here are some tips on how to use the feeder: - Use paper that is in good condition. - Fan the paper before loading into the feeder to avoid sticking together. - Make sure the paper don't buckle when loading into the feeder. - Avoid overloading.
1helpful
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
1helpful
2answers
Kyocera FS4020DN is showing paper jam in display with directions of how to resolve this issue. There is NO jam-and directions have been followed numerous times-printer has been restarted -numerous...
After removing paper tray, above the paper tray slot, on the bottom of unit, left side, is a green tab. Pull metal flap down, remove paper, and your in business. That is just my experience with my friends unit.
1helpful
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
1helpful
2answers
Paper jam message, but actually no paper jam
2helpful
4answers
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
3answers
5helpful
4answers
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
