GOT A 1981 KAWASAKI KZ1000 AND NEED HELP WIRING THE IGNITION SYSTEM FOR THE BIKE. WIRES HAVE BEEN PULLED AND CUT. IS THERE ANYWAY TO WIRE IT AND GET IT TO HAVE SPARK AND START.ENGINE RAN GOOD TILL EVERYTHING GOT PULLED AND CUT. ANY HELP WILL BE APPRECIATED.(PRODUCT NOT LISTED BELOW)
Follow the link to available downloads of wiring diagrams and other info. http://www.kz1000r.com/downloads
SOURCE: wiring diagram 1982 kawasaki ltd 750
http://www.manualz.info/
try here for a manual
hope this helps
SOURCE: looking for a fuse box panel for a 1990 kawasaki
Ok, if it's not under either side cover, Kawasaki (and others) moved the fuse box to a new place. Under the saddle. Remove your seat, and look toward the tail (rear) of the cavity underneath. There should be a little black, plastic cover that you can pop off, revealing the fuse. Found it? Great. Let me know if you need more help, Bro. TT
SOURCE: 1981 kawasaki 750 ltd bike was working and had
make sure it has the proper grade of gas. and make sure the petcock isn't plugged, they have a filter attached to it inside the tank. pretty much make sure its getting enough fuel
SOURCE: 19-95 KLF300 ATV Kawasaki 4x4 no spark put new ignitor unit on.
i ******* hate my kawasaki kdx 125 1992 there is no spark and i dont no wot it needs ive bought a cdi for it an it wernt that and i bought a new coil and it wernt that either could anyone help me please
SOURCE: my 1996 kz1000 police bike is leaking oil from the shifter side
hi buddy is it leaking oil from the shifter shaft or the left side casing if its the casing its the gasket gone or if its the shaft its the oil seal gone get back to me and i will tell you how to do it
