I have a nividia 8900 ver100 graphics card. I have searched for two days on the net with ( no ) luck. I put the card in my computer and in did'nt even light the moniter. ? DRIVER where can i download a driver for a nividia 8900 ver100 Graphics card ?
Hello the driver can be downloaded here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
By selecting the model, and your windows system.
Also try automatically find drivers for my NVIDIA products.
By installing a small bit of software, to identify the graphic card.
You just have to make sure, the driver fits your windows system 32 or 64 bit.
I suggest to use the automatic find function.
Good luck
SOURCE: Problem With Nvidia 8400 SE Graphics card
Try reflow technique.
It could work.
Its might be a GPU problem.
It can be overcome by doing reflow technique.
You
need to do following.
1. Uncover ur PC casing
2. Locate the
nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU
fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get
scrambled display/wavy screen, but wait for 5 minutes.
7. Press
reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10.
Connect the power supply pin back as it is.
11. Power on ur PC.
thats
all.
Removal of fan power, makes the GPU to get high heat, it a
reflow technique.
Remember, not to touch the GPU portion (heat sink),
as it may be in higher temperature.
Try this, it works most.
Clarifications:
[email protected]
SOURCE: graphics card has error code 10 (device cannot
Hello
I found this solution for you on Nvidia's site, the say it is only a simple setting in the bios at start up.
Here it follows:
The Code 10 error is most often a result of not having the option
"Assign IRQ to VGA" enabled in your motherboards system BIOS. Please
note: Making changes to your system BIOS can cause your computer to
malfunction or become inoperable. If you are unsure how to make BIOS
changes, don’t. Seek assistance from your system administrator or
technician. If you are familiar with making changes to your BIOS, you
may proceed with this section.
To enter the system BIOS for most PC’s, you need to repeatedly click
the “F1” or “Del” key on your keyboard as soon as you turn on your
computer until it brings you to the system BIOS. If this does not
bring you to your system BIOS, consult your motherboard manufacturer or
system manufacturer for more information. Once inside of the system
BIOS, search for the option “Assign IRQ to VGA”. Check that this
option is enabled and then save these settings. Exit the system BIOS
and boot back into Windows. The error code should be gone.
Please rate the solution.
Best regards
SOURCE: "DOWNLOAD DRIVER NIVIDIA GEFORCE FX5500
Just click here to get VGA drivers for your GeForce FX 5500 .
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
SOURCE: where can i get free download driver for graphic
Go to this page:
Then, select GeForce 5 FX Series under "Product Series"
Select GeForce FX 5500 under "Product"
Select Your Operating System and Language, then click Search.
Agree to the terms, then click Download Now, and your driver will begin to download!
SOURCE: Nvidia GeForce 7300 LE 256MB PCI Express Graphic Card driver download
Hello, you can download the xp driver here:
http://www.nvidia.com/object/winxp-285.58-whql-driver.html
This is for windows 7 and vista:
http://www.nvidia.com/object/win7-winvista-32bit-285.62-whql-driver.html
