I have a 7 year old Frigidaire side by side refrigerator with an indoor water and ice dispenser. My problem is that the water dispenser volume is so slow that it takes about a minute to fill a 16 oz glass. I have also changed the filter but the problem still persists. Any suggestions would be appreciated
Hello...have you checked the water pressure on your fridge line, and have you checked for any kinks in the line itself? If the water pressure is OK and there are no kinks in the line, then the water valve might need to be replaced. Any idea how old the valve is? It's a simple repair if you have to do it yourself. Hope this info helps! :)
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
