SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
SOURCE: How do you clean the drain filter
The door should be locked closed when a cycle begins.. That may be part of the problem.. however here is a link to the service manual for you to examine Note that page 7 shows the whereabouts of the filter,..Page 10 shows how to test the door locking system as well as drum fwd and reverse rotation...and how to drain the remaining water in the tub with the hose... http://136.166.4.200/contents/Laundry/WM2688/WM2688_Service_Manual.pdf
If you have never cleaned the filter then there is a good chace it is blocked up and water cannot drain in the normal manner so I would examine and address that first. If I've helped you resolve your problem, please input the appropriate rating .. Good Luck...
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: Wont drain or spin
I think simply your drain pump motor is stuck for what ever season. open it up and check. You will never get a spin condition if the water has not drained sufficiently.
SOURCE: just inherited this washer. TROMM
Hi
It seems something is clogging the drain pump assemblylocated inside the lower front panel of the unit. You have to clean it so thatthis issue doesn't reoccurs.
Hope this helps...please post back for further assistance.
Daniel
