We have an Everest ESF1 single door freezer. We are unable to set the temperature.
SOURCE: How to reset control board on everest freezer
Hi spider91201,
Thank you for the reply. Should you need further assistance please reply on this.
Thank you for using FixYa.
SOURCE: My Everest Freezer, Model ESF1,
Dont think it would be a door switch, defrost timer or defrost thermostat otherwise the fan (assuming it's the evap fan) would not be working, 9 times out of ten it will be a thermostat or gas leak. If the compressor (the black thing al the back) is running it is almost definitely a gas leak - you will need a refrigeration tech to come and repair the leak.
SOURCE: everest freezer esf1 error 3
I think that code is a mechanical error code. Not sure. Call the mfr and see what they say. You can google the code and model number and perhaps get it there.
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
