WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place. Let me know if you need the complete manual, Thanks, Sea Breeze
(Select Models)
Please rate me!
Thanks, Sea Breeze
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
when you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Most refrigerators with filters will not work...with a bad filter...they will work initially ...for a while after the filter indicates it needs to be changed but over time the filter can become completely clogged...and no water will flow...also the impurities that were being filtered out...are now in the water and the ice and can accumulate in the ice tray...or at the spot where water is dispensed into the tray...with real hard water calcium can build up and inhibit water flow. I would definitely change the filter..... I had the same problem and the filter and the monitor for the filter are tied into the circuitry...so yes it can definitely stop the water flow.
I hope this helps....good luck...please rate me...The Fang
There is a built in system of valves on the filter connections that enable changing filters without turning off the water. IF the filters are not fully connected the valves wont open and there wont be any water flow. .
