Sunday afternoon we used a half of bin of ice. The water tray filled up automatically. An hour later we heard the click, click, click as if it was going to drop. Well it never did. The click continued for about 20 hours. We decided to "blow dry" the ice that was in the container, and it did drop into the hopper. Since then there is no water going to the ice machine. (and all is quiet) Thank you all in advance
SOURCE: whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
SOURCE: Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
SOURCE: Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
Open up the ice maker flap and touch the tube that drips the water out...squeeze it to make sure it is not frozen. Or use a hair dryer to heat up this tube so it is no longer frozen.
This cheap fix has saved me lots of money on service.
SOURCE: Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
