I recently bought a 4GB micro sdhc card and a card reader to connect it to my computer, when i connect the reader to the computer it recognizes that it is there. but when i try open it or add files to it it says insert a disk into drive, whether the card is in the reader or not.
please help, thanks
SOURCE: sandisk cruzer micro 4GB
it may be because of the usb port of the system or the usb of the pendrive.................
SOURCE: transcend pen drive
i) this is trick i followed with my pen drive, if you an windows xp cd, insert it in ur computer and restart ur computer(follow the procedure of formating ur system or reloading OS, where u will get message "press any key to boot from cd....), make sure that ur pen drive is inserted when u are restarting ur system,
ii) i'm not going to format ur system, when u get message(to fromat in C press Enter or ESC), at this point of time u press ESC and will see all ur partition(harddisk, like C, D, E.....)and u will even ur pendrive partition separtely a
iii) and now highlight or select ur pen drive partition and press key D to delete partition and follow instruction ....after completing this deletion process, again press C to create partition........
and ultimately come out them by pressing ESC and this will prompt "whether u want to abort formating ur system, say yes..........Enter and normally continue ur operations in ur system...
iv) if u are familiar formating ur system u can do this very easily(note: i'm not formating ur system)
Thanking you
M. Sridhar
SOURCE: Please Insert a Disk in Drive H:
you can replace your usb port, or YOU CAN USE YOUR PENDRIVE IN ANOTHER COMPUTER, by which you will come to know that whether your USB port is OK or not.
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
SOURCE: "insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
i tried formatting my card using my phone * format option* and said that there was a user lock on it. When i put the card in the card reader on the pc it won't open and temporarily locks up my pc.. NEED HELP PLZ
