Frigidaire  Electric Dryer Logo
Posted on Feb 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
Bought a new frigidaire affinity electric dryer 8 mo. ago. was working fine up until a week ago. checked and everthing is working but dryer no longer heating up. After running for 5or10 minutes dryer stops but lights on control panel are blinking.
  • 2 more comments
  • jchine171 Feb 19, 2009
    How do you change this part? is there other parts that should be changed also?
    Thank you
  • Anonymous Mar 22, 2014
    door keeps popping open during cycle
  • Anonymous Mar 23, 2014
    Some of the lights on the control panel for the dry level are not working
  • Anonymous Mar 27, 2014
    INSTALL NEW
Albert Getty
Level 3:
  • Master 547 Answers
  • Posted on Feb 18, 2009
Albert Getty
Master
Level 3:
Answers
547
Questions
0
Helped
260894
Points
1266
  • Albert Getty
    Albert Getty Feb 19, 2009
    open the back you will see how it is laid out in there replace it the same way you take it out there are no other part's to change when in there but won't hurt to vac out...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
My frigidaire affinity dryer works but does not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
1helpful
My frigidaire affinity dryer is not heating up but still works what is wrong?
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dryer not heating frigidaire affinity front loader
heatman101
fgssggs
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
