Softheat Heating Pad HP218 12 3P Logo
A
Anonymous Posted on Feb 23, 2013
How to reset soft heat pad - Softheat Heating Pad HP218 12 3P
How do I remove soft touch button pad on Husqvarna Platinum Plus sewing machine?
https://manualmachine.com/husqvarna/platinum-plus/919500-user-manual/
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
I cant seem to touch any icons on my phone.
If this is the touch phone then you might ahve a faulty touch pad of the phone. remove the battery and keep aside, use a dryer to heat softly so that if there is any signs of moisture on the padd it will be taken off.
Repeat after some time but do not overheat. Now replace battery and check . If the pad responds then repeat, if not remove the phone and the pad and reset as a last try.
Sep 24, 2010 • Cell Phones
4helpful
2answers
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
2answers
Forgot password
Use Soft Key Reset
REMOVE YOUR SIM CARD
Locate your soft keys on your phone, should be buttons above end and send.
Press and hold both soft keys.
Locate reset button on your phone should be on side and in center you may need to use your stylus to depress it.
Gently press the reset button while still holding the soft keys, release the reset button but continue to hold the soft keys.
In about 10 Seconds it should ask you to confirm the reset, once you do it will be set back to manufacturers settings.
Hope this helps
Top Softheat Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
