Sir please kindly help me, my does my CCTV Camera DVR saying "UPNP Failed, Please open UPNP" I already enble the UPNP in the router but still coming the same problem
SOURCE: CIsco ASA 5510 fire wall problem
Hi Thangaraj_j,
Can you provide the topology of your setup? Can you provide also the following:
- running configuration of the ASA
- ip address of the server (what kind of server is this? what tcp/udp port does it use)
- show xlate
- show con
- show log
Just a quick try, have you tried clearing the translation and the arp table?
commands to do it:
clear xlate
clear arp
clear local
Let me know and if it still doesn't work, try to ping the server from the pc clients and see if ping does work. (you need to allow icmp to pass thru in case you are denying it for testing purposes) Just send me the additional information given above.
Regards,
ex_ocsic_cat
SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
[email protected]
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
SOURCE: block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
asowelasting
asowelasting
@asowelasting: Sir guide me, Firewall Java I'm going to update or DVR Java?
