U1000
SCP (J1850) Invalid or Missing Data for Primary Id
U1001
U1002
U1003
U1004
SCP (J1850) Invalid or Missing Data for EEC Programming
U1005
U1006
U1007
U1008
SCP (J1850) Invalid or Missing Data for Engine Torque
U1009
U1010
SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1011
U1012
U1013
U1014
U1015
U1016
U1017
U1018
SCP (J1850) Invalid or Missing Data for Throttle
U1019
U1020
SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1021
U1022
U1023
U1024
U1025
U1026
SCP (J1850) Invalid or Missing Data for Engine RPM
U1027
U1028
U1029
U1030
SCP (J1850) Invalid or Missing Data for Experimental #1
U1031
U1032
U1033
U1034
U1035
U1036
SCP (J1850) Invalid or Missing Data for Wheels
U1037
U1038
U1039
SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
U1040
SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1041
U1042
SCP (J1850) Invalid or Missing Data for Traction Control
U1043
U1044
SCP (J1850) Invalid or Missing Data for Traction Motor
U1045
U1046
U1047
U1048
U1049
U1050
SCP (J1850) Invalid or Missing Data for Brakes
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
Sounds like you are probably messing up the username and password.
"Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.)."
This is problem with graphing differential equation. InvalidAxes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image:
This graph represented differential system of equations y1'(x)=y2(x), y2'(x)=-y1(x) for initial conditions y1(0)=0, y2(0)=-1.Finally, x axes=y1(x) and y axes=y2(x)
invalid codes are not common but they do exist you will need to contact roxio inc at www.roxio.com tell them the problem supply the error install id number and they said they would be happy to supply you with a new code
DNS failed-WiFi connection error
Invalid ID or password- Carefully enter your ID and password
And the other thing you are teeling me I cannot understand , Well if it's about working of youtube it plays it quite well on mine.
This solution has helped a lot of people. The cause of the problem has been known already and is explained clearly how to fix the issue on the site link below.
