Hello try to install the chipset driver from here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=363#dl
Select download and open the driver folder, and download the chipset driver.
When downloaded run the exe program, and reboot after the install is done.
Good luck
SOURCE: Does the Motherboard Biostar G31-M7 TE work with Pentium 4
Hello there a_guerrero_d.
Here's your GEEK-steer ...
Just so I'm clear, here's what I'm hearing in your question:
If this is accurate, I believe the one operative word out of all the many above, is "DEALER". My guess is this dealer is "dealing", and either:
Per the MB's own spec-sheet, the "Biostar G31-M7 TE socket 775 mATX motherboard features an Intel G31 / Intel ICH7 chipset with support for socket 775 ... Pentium 4 Processor"s. I personally would have no hesitation pairing that chip with this MB.
In conclusion, the answer your final question: "Who has the reason". I believe it's clear that it's the "dealer" who has reason ... to not provide you with accurate advice!
Good luck, and thanks in advance for posting back ...
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Testimonial: "Thanks very, very much Geekinator for your answer. I will go to buy this Motherboard for my proccesor."
SOURCE: THE BIOSTAR G31-M7 TE MOTHERBOARD WONT START UP
Good day sir, hi. you need these 7 things to make your pc start, make sure they are good.
first unplug your pc. open the side panel to access the motherboard. Remove all connections to the motherboard.
Power on your PC.
monitor your PC speaker.
You should hear a beep, (good) one long and 2 or 3 short beeps, problem with the display card, continuous beeps, system board cannot detect memory.
monitor your keyboard.
You should see 3 sets of led light, numlock+caps lock+scroll lock, and a few seconds, 1 led light, the num lock only.
SOURCE: can biostar k8m800 m7a 754 run windows 7
The processor will run windows 7 but may not be very fast.
Look for the correct driver for the m/b at BIOSTAR.com
SOURCE: No sound on Biostar G31-M7 TE Motherboard
try getting a cd rom audio cable plug it in the back of the cd player and plug the other end into the motherboard
SOURCE: need 64 bit usb drivers for my motherboard - a Biostar G41-m7
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421
try this one
