SOURCE: washer stuck error code
only thing u can do is ring the manufacturer u should have there tel no; on your manual seems to me like these makes of washer are having alot of problems better of sticking with hotpoint or bosch they are good washer that dont break done easy
SOURCE: error code E10 on frigidaire
I have the same problem. I'm going to search the frigidaire web sight
SOURCE: error code 70 for frigidare gltf2940es front load washer
Please visit the below mentioned link to view a list of error codes of Frigidaire front load washer:
http://www.scribd.com/doc/8559708/Frigidaire-Affinity-Front-Load-Washer-Error-Codes
Thank you
SOURCE: e10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
SOURCE: Front Load Washer will not
This is an error code for a slow drain or no drain at all problem. It can be due
to a clogged/kinked drain hose, blocked drain filter/coin trap, or a
broken drain pump. The link below provides the detailed troubleshooting
procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
