What's the model number,this is a drain problem to long to drain,check the pump to see if anything is in there blocking it or you have a bad pump.
SOURCE: Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Had same problem. Followed advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
SOURCE: he3 elite kenmore- sUD and F21 error
Hello there"
Sud
SUDS
LOCK (Overdose of Detergent detected during the Wash Cycle)
The
motor control unit senses a suds lock condition by analyzing
the current draw on the drive motor. If "Sud"
is displayed a potential suds lock is detected. This may
signify a bad pump, an extra heavy load, excessive detergent,
or excessive suds.
SOURCE: Kenmore Elite error message F 02
Here is what the manufacture says about F02 - Below this are my comments
If
the drain time exceeds eight minutes, the water valves are
turned
off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed,
then
four minutes later the “F/02” error code will be
displayed.
Possible
Causes / Procedure
1. Check the drain hose and make sure it is not
plugged
or kinked.
2. Unplug washer or disconnect power.
3.
Check the electrical connections at the pump and make
sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5.
Plug in
washer or reconnect power.
6. If the above does not correct the
problem, go to step 7.
7. Unplug washer or disconnect power.
8.
Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or
small articles like baby socks you may have a plugged up pump. To access
the pump lay on the floor and remove the 3 screws holding the lower
panel of washer on. Pull down and out on the panel to remove. Lay out a
lot of towels under the unit, I mean a lot... Look in the center for a
white cap about the diameter of a large cup, it will have a handle on it
to turn, turn this left(counter clockwise) to unscrew. This will
unscrew and pull out, but be careful when it comes out so does all the
water. Clean out the trap that is in your hand and anything you see or
feel in the sump area the trap came from. Reassemble and test. If this
does not work you will more than likely need a new drain pump, that is
the component on the right of that trap you just cleaned out.
Testimonial: "You are a Guru! Thank you so much for informing us about the "hidden" trap which housed an ankle sock, .90 & lint! works like a charm now!!"
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
