SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
