17 The door / cover switch has not been opened since the last two last revolutions. The door did not open after two complete washing cycles. The door switch has not been opened since the last two revolutions. Displays "od". If the door is open, the error disappears. Check the door lock probably bad.
Also you might need to reset it.
... Press power/cancel then start/pause
Press power/cancel first.
Next, pick a fresh cycle to run.
Press start/pause to reset your Maytag washer.
Run a test load afterward to confirm that the washer has reset.
Possible that the suspect seems to be the programmer timer unit. It is possible that on the selection of normal and power wash there are connection issues. Try and use a switch cleaning spray and check for the stepper motor functioning when the program runs. check and tighten all connecting leads from and to the timer unit before estimating the cost.
Hello there,
I would suggest that you take off the battery first overnight. This will discharge the power totally and will let you run a power cycle. The next day, try to charge it again. Let me know what would be the results after that.
Sounds like all you need is a new pump motor. Pretty common issue. Fairly inexpensive motor. About $30+ on amazon. Check out repairclinic.com or appliancepartspros.com for part numbers and repair videos. Good luck.
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
