I had water in the fridge compartment of my Moffat fridge so I cleaned out the drain in the freezer. I poured warm water on it until it thawed and could hear the water running down the drain onto the evaporating pan. After I started the fridge up agaain I noticed water in the fridge compartment again. Seems the drain may have frozen again?
This link should help you sort this out. Drain freezes in moffat fridge Google Search
SOURCE: Moffat Freezer
Things to check Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor & IF it is running Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
SOURCE: What should the dials read in a moffat fridge for
Always start by putting the controls at the mid-range position for the first 24 hours. Keep dual control models settings equal to or +/- 1 position from each other for optimum performance. If an adjustment is made, wait 24 hours before making another adjustment.
If you have to start making adjustments then this may be a sign that something is malfunctioning. Take steps to preserve all perishable items before servicing unit.
Things to check
Check freezer...
Check condenser...
My drain freezes up in the bottom of the fridge as well as ice forming under crispers. I temp is turned to the lowest point without being off. Now I am getting ice crystals in the freezer.
