GE GSS20IEP Side by Side Refrigerator Logo
Luan Posted on Feb 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Side by side refrigiretor frizer model 106.57604500 .automatic water filter stop working and periodicly beeps .How can I fixed please ?
Side by side refrigerator frizer model 106.57604500 .automatic water filter stop working and periodically beeps .How can I fixed please ?
Richard Roth
Level 3:
Top Expert:
  • GE Master 9,472 Answers
  • Posted on Feb 17, 2013
Richard Roth
GE Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626548
Points
28464
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 28, 2009
SOURCE: Defrosting of freezer periodically
You could have a problem with the defrost heater or it could be a problem with the control board. Hope that helps.
Anonymous
  • 35 Answers
  • Posted on Mar 27, 2008
SOURCE: GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Anonymous
  • 4 Answers
  • Posted on May 18, 2009
SOURCE: Water periodically leaking from under refrigerator
we had this problem. Repair guy took all contents from freezer, defrosted it. There is a hole near the bottom in the back. It is for overflow. It was clogged or too full. Make sure the hole is cleaned out. Works fine now.
Anonymous
  • 71 Answers
  • Posted on Apr 01, 2010
SOURCE: Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Anonymous
  • Posted on Mar 07, 2011
SOURCE: GE Profile REfrigerator: Model
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
1helpful
My Frigidaire side-by-side leaks inside, from water filter
the gasket that holds the water pressure in between the water inlet line and filter is not in proper position, or your filter sir is nt properly inserted into the slot,the cycle starts when the water comes in,pressure will build up and it will start t pass in between the gap, as the pressure goes down, dripping will stop, then cycle start again, check the connector sirandhose connected into the filter
I changed filter, the water flow is fine but no water come to the frizer, I hear the click click like if is making Ice but nothing happens.
check the solenoid valve on the water line to make sure it is not stuck or bad crack the line coming out of the valve to insure water is moving passed that point if so then you either have a clogged line going to the ice maker or a frozen or clogged jet
4helpful
3answers
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Top Refrigerators Experts
vince
Johnny 1000
