SOURCE: xenon lights blown fuse
You could have a problem with the xenon light itself on the passenger side or the wiring running to the light assembly.You could unplug the connector from the light assembly and replace the fuse if it still blows the fuse, its in the wiring harness if it doesn't it problably is in the light assembly. I'm not sure how the lights are configured on the Z if the zenon lamp is replaceable by itself, you can try swapping it out. I haven't had any problems with my Z but those are a few suggestions on troubleshooting your problem.
SOURCE: 2002 Acura MDX door lock fuse blows
It sounds like the circuit has a short in it somewhere. You can check for grounding with the same tester your used to measure the amp draw. Connect the tester and put it on continuity, this should sound an alarm when a closed circuit is detected. Move the harness around to see if it goes off.
SOURCE: 140 amp fuse blown request replacement instructions
you have to remove or access the bottom half of under hood fuse panel to remove bolts on teh bottom of that fuse.
SOURCE: Fog lights keeps blowing fuses
Obviously a short somewhere. Check sockets for corrosion, rust etc where current could be traveling across, as well as take a look at wiring into rear if you can get to it. One other thing you could try to isolate, would be to try one bulb in at a time, perhaps one will cause fuse to blow & other won't, which will give you a reference point to start looking.
SOURCE: has recently blown inline 15 amp starter motor
Hi
DO NOT put a bigger fuse in ,you need to find out why the fuse blew in the first place,it is unlikely to be the starter motor,it could be a bad connection,the mercedes all have problems with the ignition switch assembly this is more likely.
Got pulled over by a sheriff couple of nights ago for this one ..... like me, it seems your "headlight dimmer control switch" has gone bad. You most likely may have highbeams but no low beam, marker, or tail lights unless you step on the brakes. If you go the Pep boys route it'll cost roughly $80. .... at least thats the quote for my 95 Grand Am, which is why I'll be checking out the area junk yard. They sell 'em for $5 ...... hope that helps. Ron J.
If your dash lights are not working check your fuse block, see owners manual, it is most likely that the fuse has blown. If it's blown then you need to replace it. (Usual cost for the fuse is under $2.00) If the fuse blows again then the short must be traced down and repaired. Start by checking the bulb sockets(see owners manual) then look in other locations were the wire might come in contact with , Look for frayed wire insulation and wrap with electrical tape. If the fuse is okay your problem is harder to solve. I'm experiencing the same problem with a '88 Ford Crown Victoria. All components are working properly. There's powe to the fuse but none to the lights. I've been working on a solution for 3 days. Tomorrow I'll run a bypass from the headlights to the parking lamps, through a 15 AMP fuse of course, as a quick fix. If you follow the previous answer and use a 2nd hand switch be advised that you may have to remoce the entire dash to access the switch to remove and replace it. Good luck
Read more: http://wiki.answers.com/Q/Tail_lights_don't_work_but_brake_lights_do_work#ixzz1LQI2yL3G
